MSD Blaster 2 Ignition coil
Old Sep 12, 2009 | 11:54 AM
EBE23's Avatar
what is the easiest way to install this on my 91 nissan 240SX SE 2.4L KA24DE. I already have a stock ignition coil in thats mounted on the tire fender whell. I wanna make it look as clean as possible and if possible I wanted it mounted on where the factor ignition coil is.
Old Sep 12, 2009 | 12:03 PM
Nickmerrone's Avatar
x2. i need this. lol
Old Sep 12, 2009 | 12:37 PM
Ask Jesus he has it on his s13
Old Sep 12, 2009 | 12:41 PM
Dude, i just called him. He said he forgets, he upgraded to coil packs.
Old Sep 12, 2009 | 02:18 PM
carps13guy's Avatar
the blaster coil looks like it is about the same size as your stock, but just a little bigger. im sure you could modify the mount to fit it. i actually remember seeing one on a local s13 in auto class but didnt really pay too much attention as to how it is mounted. but i know its possible!
Old Sep 12, 2009 | 03:19 PM
if your looking for a mount, buy one for it..i did. i just need to install the blaster..
Old Sep 12, 2009 | 04:26 PM
Preston's Avatar
Installing is easy...old power and ground wire off of stock coil to power and ground on the new coil. Plug the coil wire onto the distributor and drive.
Old Sep 12, 2009 | 06:56 PM
you must have asked the wrong guy.
https://www.s-chassis.com/forums/how-tos-installations-48/msd-ignition-coil-modification-obd1-kas-39479/
Old Sep 17, 2009 | 09:08 PM
SmokedZenki's Avatar
what i think sucks is i cant upgrade to an external coil like the s13 because my s14 has an internal coil in my distrbutor...?? correct me if im wrong... hopefully im wrong..
Eric
Old Sep 17, 2009 | 09:16 PM
Eric
your not wrong, you cant do it.
anyways, didnt realize how easy this isntall was..
Old Sep 17, 2009 | 09:31 PM
you might want to relocate that coil, ignition components don't like the heat.
Old Sep 17, 2009 | 09:47 PM
I asked a bunch of people, they said it should be fine, i wanted to relocate it, but the cars been run like for a good amount of time and nothing happened..
Old Sep 18, 2009 | 11:41 AM
BigVinnie's Avatar
Yeah dude I was about to say coil packs for a KA24e highly unnecessary.
Old Sep 18, 2009 | 05:58 PM
BigVinnie's Avatar
Who feed you the horse sh%t.
http://jimwolftechnology.com/wolfpdf...SR%20240SX.PDF
Old Sep 18, 2009 | 07:21 PM
Originally Posted by BigVinnie
I thought he meant the blaster im using, the ****ty one.
