my engine keeps shutting off
hey guys, i need help on this situation that i have. everytime i drive my car it shuts off a lot. i dont know whats making this problem but i see my rev meter stick dropping below 1 and it keeps bouncing, could it be my throttle krap? i need to tighten that up? or what are your guys thoughts about this problem that i have, it gets annoying especially when im turning ohh and this only happens in neutral......or pretend im at a red light.. i just tap the gas a lil .....and there it goes. so what are your guys thoguhts about this.. its a stock 93 240 ...thanks a lot
-b1 |
Sounds like a problem my friend had on his 92 prelude, he would come to a stop and if he didnt keep pressing the gas the car would shut off. We fixed it by adjusting the intake(throttle body), raising the idle speed to about 700rpm. is this what you mean by throttle krap(sp?)...hope it helps
hey thanks a lot, yea thats what i had on my mind too but wasn't sure. i'll go check it out rite awway...
700-800rpm??
Whats up ur car is suposed to idel at about 7-800rpm while stopped thats the ideal position.. My car rpm's jump and drop only when my compressor is on... I have a good friend with the same problem please let me know your outcome.. megocrazy21@aol.com
I have the same probem. If I have my idle set at about 800, it will die everytime I push in on the clutch. But if I raise the Idle up to about 1600 it will drop down to about 500 when cold and 800 when hot. Which stops it from dieing at corners but isnt to good on the engine since after I set for a few secs. The idle slowly raises to 1600 until I take off again. I was told it could be the EGR valve but it cost about $100 for one and I dont want to spend the money if it doesnt fix the prob. So if anybody has any idea PLEASE!!! :tear: help me!!. I also heard it might be a AAI or IAA valve or sensor or somthing but I cant remember what they said.
