n60 and safc
from what i've read you can install the n60 with out a safc but it will run pig rich. however when you do install the safc and setup the in/out's is there anything else that would need to be set to get the car running correctly?
if you don't wanna buy a wideband.. you should take it and have it dyno tuned... because even in NA form bad A/Fr's will hurt your motor.
