Need help Mass air to much fuel
I have a new o2 and new plugs and new wires and good spark but the car is getting to much fuel and wont idle I need help
Originally Posted by Alexl08
(Post 323256)
What is your MAF labeled???? |
what do you mean the parts numbers match but does it make a difference between auto and man sensors
(Post 323408)
the last three numbers say g60
HMMMMM.....
If I were you I would run an ecu diagnostic first. If there is a problem with the MAF it will throw a code. If not then I would check for leaking injectors, more than likely you could have a bad injector. |
