need help on motor swap
I recently blew up my ka24de and I just bought another one with 60,000 miles out of an automatic 240. The problem is that the inlet into the crankshaft where the tranny shaft goes seems bigger than my old one. Now Im trying to figure out if it will still work out. So is a ka24de from an automatic comatipble with my 5-speed tranny? help
I believe that the manual and the automatic have different drive shafts, not positive though
You sure you got one from another 240sx I know they have them in trucks also. Maybe it could be from a truck with a different driveshaft.
They should all be the same...Do you ahve all the nec. parts? And are you sure its from a 240?
driveshafts are different dependent on manual/auto, and abs and non abs.
Dr. |
