need some help
hello everyone. I have been on this forum for a while, but never posted. Well now I have a problem I just can't seem to figure out. I recently bought another s13, 1993 se automatic, and it runs fairly well. The problem is when I turn either left or right, say like turning out of a parking lot or at a light, the car bogs down or sometimes shuts completely off. I have never seen anything like it, and since my wife can't drive a manual tranny car, this is her only mode of transportation right now. I really hate to just trash this car, but after dying in rush hour traffic and nearly killing my wife and 2 year old daughter, not mention the other drivers and passengers, this car may be on its way to the heap!
check the wiring, it may be coming loose, also under the fender wells to make sure the tires havent torn any wires up, check fuel pump to make sure its properly tightened...hmm i duno
thanks i will take a look at it in the morning, I cant have this car just cutting off or dying when I go to turn onto a busy street, its dangerous as hell
i could be off but this happened to a buddies Honda. If you check the wiring on the Power Steering pump...or just replaceing it, it could fix your problem
Power Steering Pressure switch.
Driver's side of the engine bay Follow the line from the hose from the Power Steering tank down to near the frame rail. The switch should be the only thing down there with 2 wires going to it. When the switch senses pressure, the ECU increases the idle enough to keep the engine from bogging down. |
