New rings or not...
New rings or not...
I am in the middle of doing a valve grind to my 89 240sx (230,000kms), and i was thinking of replacing the piston rings while I was at it...
Does this sound reasonable? or should I leave well enough alone, and just put the head back on...
If I change the rings, should I change anything else, or can I get away with reassembling the connecting rods/etc with all the same bushings, etc...
I decided to leave well enough alone... compression was 140-150 before, and there is absolutly no wear on the cylinder walls. I'm scared if I screw with it, it may make things worse.
I did change the rear main seal and clutch when the engine was out anyhow.
swiftstyles
May 4, 2005 11:05 PM
bavsport318ti
Apr 6, 2005 07:53 AM
