-   NA Motor (https://www.s-chassis.com/forums/na-motor-11/)
-   -   New rings or not... (https://www.s-chassis.com/forums/na-motor-11/new-rings-not-13371/)
markheth Jun 16, 2004 08:05 AM
New rings or not...
I am in the middle of doing a valve grind to my 89 240sx (230,000kms), and i was thinking of replacing the piston rings while I was at it...
Does this sound reasonable? or should I leave well enough alone, and just put the head back on...
If I change the rings, should I change anything else, or can I get away with reassembling the connecting rods/etc with all the same bushings, etc...
Rouge S13 Jun 17, 2004 08:49 PM
if you change the rings change the crank bearings also.
markheth Jun 18, 2004 05:59 AM
I decided to leave well enough alone... compression was 140-150 before, and there is absolutly no wear on the cylinder walls. I'm scared if I screw with it, it may make things worse.
I did change the rear main seal and clutch when the engine was out anyhow.
