now its shot.
welp i been dicking around trying to get this engine mount off and now today when I went to go pull the covers off my engine... freaking water inside my cylinders.... i just rebuilt the damn thing and now I"m f*cked! right guys?
no your not f***ed... clean it out...if there is rust in there all ya have to do is take off the oil pan and the front cover... remove the crank rods and pistons... get the hone out again and re hone the motor... if there is no rust... clean the water out and wipe the pistons and everything off... pull the oil pan plug and make sure there is no water in there as well... spray the walls down with more wd-40 and cover it better...
okay one thing you said make sure no water is down in the oil pan.. what if there is then what? the crank and bearings are f*cked??
not at all... if you used good assembly lube then all i would say is pull the oil pan and re lube the bearings... thats all ya gotta do...
i think it was pretty good stuff.. i don't know i asked for it at auto-zone and they gave me a tube of lube that was blue and red colors on the package.. don't remmeber what it was called but it was only like a dollar i think for it.
wikd240,, just took the block apart today.. **** load of water came pouring out when i started to tap the front cover off... : (
btw. do you have my new aim screen name??? |
take it all apart pull the rods and pistons clean everything and put it back together... as long as there is no serious rust in there it should be good...
i dont think i have your new aim screen name... can i delete the 5 other ones i have you under??? |
hahaha yeah you can get rid of them.. i'm gonna IM you now on my new s/n in like 2 seconds.
