overrevving problem
overrevving problem
I just got my car running again afte aout 2 years i did a de swap in my 89 s 13. its running kinda rough and sometimes it wants to rev up to about 4000 rpm.and once you rev it alittle the rpms are really slow to go back down. i'm sure that the rough running is a vacume problem or somethig like that. but whats up with the high rpms and the slowwreturn to idle??
Air intake control valve
its the purple plug on newer manifolds brown on older ones.. make sure its plugged up.
here is a picture of the back of my manifold for reference.
Oh sorry big. aha. and Big, I'll be posting something in my build thread a little later. Can you take a look and help me out? ill take alot of pictures, i just need a few intake manifold questions answered. haha.
while the iacv may be partially to blame, i've never seen it cause an engine to idle higher than 2.5k rpms. that's not to say that it can't happen, i've just never seen it happen. i don't suspect a vacuum leak either, i'm thinking that something may be causing too much fuel to be dumped, that would explain all the symptoms.
but like always i recommended you check for trouble codes. checking for codes doesn't always provide a definite answer, but it typically does narrow the list pf possible problems.
