Progress with a twist WHAT IS EGI??
I recently pulled the Head on my KA24E a had it
rebuilt w/ new running gear / port and polish as well as the new Colt triflow cam installed. The car is buttoned up now and runs great!! My issue is this. I also plugged in a Jim wolf ECU and when I turned the ignition to the on position the EGI relay fuse started to click.. tick tick tick .. What is that??? I removed the ecu because I did not want to start the car not knowing what was going on. I plugged in the stock ECU and all is well... So What is the EGI Pump for and what does the EGI Relay fuse control? Jim Wolf tech quoted me 100 bucks for repair.. !!! Wha Whaaa It can take much to diagnose a ECU and probobly less than 1 hr to fix what may be wrong.. seems like highway robery.. Does the Jim worf ECU even let you log info>>?? I also plugged in the FAST CHIP that I recieved from the e-bay vender drape123 at E Formance and the tick tick tick was not happening but the car would not start up... It's probobly garbage... Any assistance would be good. Thanks Brian |
