Project Car wont start (KA24DE)
Bought a project car recenly with a bad(as in didn't run but owner didn't try to get it running) motor, but hopes of it working. Today I'm trying to get the motor running and having an issue. It cranks over fine but does not catch and run. I have checked the spark using a test plug (The thing you ground with the clip and watch for a spark) and also checked the plugs that they were correct and gapped correctly according to advance auto. I also checked the fuel system and know im getting fuel all the way into the fuel rail. I messed with the distributor and even running it through its entire range, I get nothing. It looks like spark is fine, and all I can think of is one of the injectors is not flowing. The previous owner said the motor was swapped in and ran before the swap, but didn't after. It is a 92 KA24DE in a 93 coupe chassis. Any ideas?
you can use any OBD1 (91-94) ecu only difference between them all are slight tune differences.
do an OBD check and see what codes it throws at ya. i second the compression also. |
even if one of ur injectors wasnt flowing ur engine would still start an just run on the three cylinders, id thuroughly look over ur wiring harness, connectors wires ect.. and check for codes an see what comes up and like biggamehit said u can use ne of those ecu's, was the ecu swapped with the engine or did u just use the one in the shell? do u no if that ecu was running right in the first place?
The previous owner said they just dropped in the motor with out swapping ecu's. I did a compression check......40psi on the front cylinder, didnt even bother testing the others. I pulled off the valve cover to take a look at the setup and there is oil/water mix up there. Looks like someone poured skim milk into the top of the motor. I think it may be the head gasket, so I'm going to treat that issue and if it still doesnt work, the car will just sit until I can afford the SR20DET. I bought the car assuming the motor was a paper weight, so I'm not really out anything in the long run. I figured it was going to sit in the garage waiting for a new motor and Silvia nose pieces.
yep HG
The first thing that I would do is check what codes the ECU are throwing, then if that is fine I would check the timing. Check the oil to see if it is milky looking or clean. Is there an alarm on the car that might be killing the starter.
Was it just a simple swap or did this person have the cams out replacing the timing chain or anything like that? more info would be nice. |
Originally Posted by dkdeleon
(Post 375571)
Was it just a simple swap or did this person have the cams out replacing the timing chain or anything like that? more info would be nice. BTW drained the trans, the oil and the rad this weekend. The trans fluid was brand new but the drain plug was covered in metal shavings. The engine oil was brand new, never run, but reeked of gas. Not a sign of water in the oil......OR the radiator for that matter.......:angry: |
40 psi is bad very bad the lowest psi level should not be lower that 155. with a 10 psi spread across other cly.
ps the max is 175 btw |
(Post 375736)
ps the max is 175 btw So..Anyone wanna buy a used KA24DE, doesn't run but seems a fixer upper:thumb: j/k Ill probably part it out on here unless I can find a local who wants to try thier luck at it or needs a project big bore motor. |
you should check compression in the rest of the cylinders before you part it out. if the rest have good compression then it should just be a matter of replacing the head gasket and maybe a valve job while the head is off.
Uhmm Hmmm Ummmm HMMMM
(Post 375858)
in that case forget i said anything.
btw nice car. |
dammit... i was going to ask you if you checked you Glo Plugs
