Questions about crank angle sensor
Old Jun 5, 2007 | 08:41 PM
MasterOSkillio's Avatar
I seem to be having a problem with my crank angle sensor; it keeps setting off ECU codes, every two to three weeks. I was wondering if having an aluminum flywheel would cause that to happen. Through googling around I found out that the crank angle sensor has a magnet, and it detects the difference in gear teeth on the flywheel. Considering that I have changed the stock flywheel to an aluminum Fidenza one, I was curious if that would cause the sensor to not function correctly.
If that is not the case, what other then a bad sensor would cause it to throw codes? Could there be another thing might be broken that I am missing?
EDIT: This is a 95 240sx OBDII
Old Jun 5, 2007 | 11:29 PM
BigVinnie's Avatar
What code number is your ecu throwing?
Old Jun 5, 2007 | 11:39 PM
Number 82, and every time i reset the ecu 82 comes back again later, any ideas BigVinnie?
Old Jun 6, 2007 | 11:20 AM
clubredsilvia's Avatar
^^ an aluminum clutch should till have chromoly teeth/ friction surface.
Old Jun 6, 2007 | 01:03 PM
Then I am totally stumped, has anyone else had this problem? What else should I even be looking at?
Old Jun 6, 2007 | 03:07 PM
BigVinnie's Avatar
The sensor itself could of become damaged when the fly wheel was installed.
I would look into replacing the sensor. You shouldn't be having problems with the aluminum flywheel installed.
Biggamehit
Nov 30, 2009 05:58 PM
xQwertyx
Apr 29, 2006 11:01 AM
sils13rwd
Jan 22, 2005 11:42 PM
chuckie500
Oct 1, 2004 01:05 PM
tegg_gsr
Feb 7, 2004 08:34 PM
