repairs
I've got an oil leak coming from a bold on my valve cover how hard is it to replace the two valve cover gaskets and also since last night my car has been feeling like it's being pulled back while I'm driving or the engine is sort of stalling after I've been driving at a steady speed for a little while...god knows how longs since it's had a tune up because I bought it from an idiot but is there anything else that could cause it to studder or whatever when I'm driving? thanks
Kevin |
Clean the injectors, or buy some new ones.
no, the valve cover gaskits are easy to change just follow the bolt loosen patern and tighten patern wich are to start in the middle and loosen your way out to the edge for loosening and reverse the order for installing hope this helps
