as some of you know...
as some of you know already i am rebuilding my ka back to stock because i blew up my rod bearings in cylinder 2. today i installed the new main bearings, new crankshaft, replaced my rod bearings with new ones.. replaced my rings.. I am having a lot of problems getting piston into cyliner 2. I done all my others juist with the piston ring compresser and cylinder 2 is being a dick! what would be wrong? my guess is when my rod bearings went on cylinder 2 that the rod is weak but it doesn't seem it to me so i dont know.. my guess 2 is that piston is bad. Can anyone help me out? thanks
also like devious said check the grooves iif there carbon buildup you missed it might not be allowing the rings to seat properly..if you still cant fit it in there check to see if they gave you the right rings..(scratch this if your reusing the old ones)
