sr fuel rail on ka
I'm thinking of getting a sr fuel rail with the injectors. Because 1 of my injectors is leaking gas and it reeks of it. Is there any possible way to make the sr fuel rail fit onto my ka motor? And is there any possible way to have to avoid soldering the wires together? Or is it sure that soldering will be involved?
just buy an injector
KA and SR fuel rails are both rated to take upto 250CHP. Just change out your injector.
I won't have to solder wires, however I do it, right? I can't solder at all. I asked my brother cuz I know he soldered his but he says he doesn't know. But he had his wires cut. If I get uncut wires they can just be plugged and play? Or whatever...?
Originally posted by Silvia1EightySX I won't have to solder wires, however I do it, right? I can't solder at all. I asked my brother cuz I know he soldered his but he says he doesn't know. But he had his wires cut. If I get uncut wires they can just be plugged and play? Or whatever...? unless you or some one else have cut the connector off of your harness all you do is dissconnect your leaking injector, remove the injector then replace with new injector and reconnect the connector. thats it no soldering involved unless like i said above you or some one cut the old connector. if you did i dont know why??? |
Ok cool. I was asking some people I know and they were like I don't know. I've never done this so I don't know about it yet. And even when I asked if no wires were cut, person still said I don't know. Thanks!
