Starting engine that has been sitting for awhile
Hey, can you guys tell me what i should do to prep the engine that has been sitting for awhile before i start it up?
Thanks, Jeff |
Drain all the old fluids out and put new fluids in, check belts for cracking, check vacuum hoses for cracks, check out your intake box for spider webs... put 2-5 drops of oil in cylinder.
may want to also pull ignition or fuelinjection fuse and let it crank a few times and circulate oil throughout under low load. not neccessary though.
