Starting problem.
Old 04-30-2009, 03:05 PM
Xoltol's Avatar
Starting problem.
WEll i was driving my 240 back home from orlando, In the middle of driving i herd a loud bam noise, then my 240 refused to start... It sounds like a helicopter when I turn the key.
Any ideas?
The girl who helped me tow it said it might be a pully or a belt.
Xoltol is offline
Old 04-30-2009, 04:59 PM
shaban's Avatar
Check your timing chain.
shaban is offline
Old 04-30-2009, 05:46 PM
does it sound like a helicopter when you turn the key or when the engine crank?
jramosthe1st! is offline
Old 05-01-2009, 12:55 PM
Xoltol's Avatar
When i try to crank
Xoltol is offline
Old 05-01-2009, 02:46 PM
so does it sound like a helicopter when you
a)turn the key?
b)when the engine cranks?
c) there is no "c"
Old 05-02-2009, 07:34 AM
Xoltol's Avatar
Sorry.
Let me be more clear,
It starts and such, but it makes a LOUD helicopter ish noise. when left on, and the whole car vibrates.
Xoltol is offline
Old 05-02-2009, 02:53 PM
it's possibly misfiring, which means you should inspect anything ignition and timing related. that would involve some wishful thinking though because of the loud bam you mentioned. have you noticed if the engine take longer and longer to start every time or does it start like normal? also what year and engine does it have?
Old 05-02-2009, 04:58 PM
Xoltol's Avatar
Same amount of time to start inbetween, Just a loud helicopter noise
I'll check the ignition and chain and i'll get back to you.
Xoltol is offline
Old 05-02-2009, 05:16 PM
if that's the case and performance hasn't changed i'd be more inclined to believe that you have an exhaust leak. if there has been a change in performance i would suspect you have a blown head gasket or something of the sort.
Old 05-08-2009, 09:30 AM
Xoltol's Avatar
OK!
Checked the timing chain and no, thats still good, I can turn the car on and let it idle if i wanted too, I just refuse to.
The noise more accuractely sounds like your Knocking on metal, Like a hollowish knock.
It increases speed when i rev, and when i started the car, it went away for maybe 3 seconds then became steady.
Worst fear, I have an knock in the engine.. which is what it sounds like, least worst.. Someone hasn't changed the oil and i'm getting dry.
Xoltol is offline
Old 05-08-2009, 09:37 AM
240smoke's Avatar
Sounds like you have yourself a blown KA. Check your compression.
240smoke is offline
Old 05-11-2009, 10:30 AM
YangpaNemsay's Avatar
Originally Posted by 240smoke
sounds like you have yourself a blown ka. Check your compression.
+1
YangpaNemsay is offline
Old 05-24-2009, 10:54 AM
sav180's Avatar
damn im goin thru that same bs .but my motor wouldnt rev over 5 grand and when it did iit started makin that tappin on metal noise..horrible
sav180 is offline
Old 06-08-2009, 06:41 PM
EBE23's Avatar
ya do a compression tests on the cylinders 1st. Is there any water coming out the exhaust? have you driven it since? loss of power?
EBE23 is offline
240sx 5spd
07-14-2004 10:31 PM
gerbort
06-08-2004 07:46 PM
flyingmo13
05-28-2003 09:43 AM
Ozzmosis
05-05-2003 07:56 PM
Quick Reply: Starting problem.
