thermostat housing
Hi, I am a noobie. I have a 92 240sx. While changing the thermostat the housing (part that thermo fits in) cracked. I want to weld, but would like some suggestions:dunno:
the way i look at it, is that may be a temporary solution. if you can weld then do it and keep an eye on it till that new part comes in.
where you get your OEM parts from? |
there is nothin like jumpin in your car and havin nothin to worry about
Thanks Rudeboy, But if weld does not work, then I need to find a used part. The new cost $400 or better. The chipped part is less than an inch long. $400 for less than an inch chip....:tear: Must be a better way to solve. Can not find wrecked car to get part...:anger2: Started out as a simple repair now something serious:tear:
$400...tell me what part again just so we're not on diffrent pages here.
http://www.autopartsworld.com/index.asp try this place. i got my timing kit from em. cheaper then courtesy. i'm not sure what part you're talking about exactly. i was under the impression the thermostat was in the timing cover. but i also have a 90. my whole tining cover was olny $90:thumb: |
I'm gonna move this to Naturally Aspirated forum.
Ok Rudeboy, the thermostat fits into a housing. The housing is attached to the engine. The housing has three bolt holes in it. When you place the cover over the housing you then pass the bolts through the cover and screw the bolts into the housing. The lower bolt hole (that is part of the housing) has broken off. To make clear...the part that the thermo fits into is cracked....That part is not a stand alone...it is a plate that goes across the engine...the water pump bolts onto it....hope that was a little better:confused:
ok. that helps. i got that piece from Nissan for $95
alotta places dont have the part # so call Nissan get the part # and leave emails. you can find a good deal if you look. and the best part is they're all OEM stuff. the link i gave you won't have it either. #1) get the part number #2) get quotes. #3) isn't that aluminum? don't weld that.:nono: i think when i called for mine they thought i said DOHC and quoted me $125. 2 day wait from the dealer. DON"Y PAY TO HAVE IT DONE_IT"S SO EASY . pain in the ass but easy |
1 Attachment(s)
old and new
Yeah it is Aluminum. I went to dealer just to get quote($400) and to see how to put on. I will take advice and search for better deals. I will keep you posted. Thanks 240million....
Topless In Ga |
Hey, Thanks for PIC's, mine is a little different....will do the work myself....can not stand another man touching my baby:nono: LOL
We will talk soon. Topless240 |
even with the diffrences between SOHC and DOHC it's still crazy easy.
even if you buy the factory service manual(our bible) it'll save you tons. and just so you know you use permatex not a regular gasket |
