Timing- Miss Firing- No Power
CAN ANY ONE TELL ME THE ORDER OF THE PLUGS WIRES IN THE HEAD IN RELATION TO THE DISTRUBTOR CAP.... MY CAR IS ACTING UP REAL BAD, i LISTED MY ORGINAL POST BELOW....
NO ONE ANSWERD SO I WILL TRY TO ASK AGAIN THANKS j I have a 91 240sx.... Like i said before.... I took it to get the clutch slave cyclder worked on and now, the car is misfiring and runs like crap. I gave the shop the benifit of a doubt and changed the wires and plugs, nothing.... Any other ideas.... should i just take it to a shop to have them looked at? would really like an idea or any suggestions.. my suggestion is to go burn down the shop.. help me, Jay 600 dollars and my car is running like helll....:angry: :angry: |
the distrobutor cap should have numbers on it... or atleast mine did... i dunno.. i don't own a 240...
Originally posted by EvilCerealBoX the distrobutor cap should have numbers on it... or atleast mine did... i dunno.. i don't own a 240... ALRIGHTYTHEN - is it a KA DOHC? I'm assuming so since it's a 91... if you stand on the left side of your car looking at the engine and the distributor cap, here's the order for the wires on the distributor: top left - 1 top right - 2 bottom left - 3 bottom right - 4 As for the order on the head, it goes 1-2-3-4 from front to rear. Try it. Kay:thumb: |
Thx a ton..... I got it.....
plugs - wires- cap - rotar- and everything seems to be fine now..... going to remove the aiv next..... thx again, J |
Originally posted by drifterswanted Thx a ton..... I got it..... plugs - wires- cap - rotar- and everything seems to be fine now..... going to remove the aiv next..... thx again, J |
