TPS SOHC question???
I have an 89 s13 and was checking my tps sensor the other day after doing my timing . When in the throttle is closed it activates the idle switch but at full throttle it doesn't activate the WOT switch(no continuity between middle and top terminal).
I wanted to know if that is how it is supposed to be or do I have to adjust it?? Thanks, |
