transmission oil
I need to change the grease in my tranny. How do I drop the linkage so I can remove my shifter to re-fill the tranny or is there any other way to re-fill the tranny?
I assume you mean standard transmission.
There is a drain plug on the bottom & a fill plug on the side. Also it's gear oil. Not grease. Use 90 weight |
ohhhh ok THANKS MAN! im a newb. still learin
if you got money..use redline gear oil :)
If it's a racer yeah.
But I use Super Tech syn in just about everything.( Yes the Super Tech from Wal-Mart). Refined by Pennzoil & put in a Wal-Mart bottle. |
apparently redline 75w-90 with frictional modifiers is the best for lsd, racing, or break in
otherwise a synthetic 75w-90 for daily driver if you cant get to the fill plug ive heard you can unscrew the shifter and pour it in there too. |
How many qrts?
2.5
I was thinking of doing the same to my 95 S14... is the method the same (drain plug, fill plug locations?)... also, do you have to drop the tranny out of the car just to do it, or can it be done on jack stands?
Yes. No. Yes.
Originally posted by JeromeS13 Yes. No. Yes. |
Umm... I heard it was 80-90 gear oil.
