Valve overlap?
Yes, the 240 engines are interference engines, as are most 4-cylinder engines. That means that at the piston's highest point and the valve's lowest point, there is overlap. If you throw a valve or break ur chain, you're pretty much screwed.
SOUND2NR
07-28-2002 09:44 PM
