Venom Injectors?
Around how much HP would venom injectors add, and would it take alot away from my gas mileage?
Ryan |
not a good idea to just upgrade your injectors, you'll run rich, anywhere from 10-20mpg. If you upgrade the injectors you'll need to upgrade the fuel pump as well. Not a common mod unless you're going KAT.
Dr. |
yea I am doing a KA-T, I ment to put this in forced induction. Just forget bout it I got outbid any ways, vortech fmu should be fine.
Ryan |
so does this work both wasys??? imean can i change the stock pump to a 300zxtt pump or do i have to change the injectors too?
