what do you think of these fuel injectors?
i just bought these, and they seem perfect for what i need. what do you think about them.?
http://www.prostreetonline.com/buy/venom_injectors/ |
what are your plans for the car... you stated they seemed perfect... what is the setup and we might be able to help you out...
im waiting on the motor to get done now, its in the machine shop. i have 89.5 cp forged pistons going in with crower rods,and a cometic head gasket, p&p head, new timing chains, and new oil pump... venom 400 module,cold air intake , dnx exsuast, obx headers, racing pulley, ngk plugs with nology hot wires, stage 3 cutch master, fidnanza flywheel, 300zx tt fuel filter, 255 fuel pump, i have the venom injectors now, high flow cat, machanical fan removed, msd ignition system and a 2nd coil, and a nx nitrous 75 shot stage 2 kit set at the gas pedal so you have 75 shot every gear, with electronic rpm set up. my plans are to get the crower cams, and ti retainers and valve springs soon, and a turbo down the road witch will come with the injectors i will need when i get it. shouldnt these injectors give about 15 more hp if the car is puting it out?
Injectors give zero horsepower. They either have enough capacity or they don't.
It isn't mentioned what the CC rating is? What did you upgrade the injection too?
Personally I would of just ordered some used JDM sr20det 370cc injectors for $100. I wouldn't use the Venom Module either, it's limited to its functionality. Safc is a much better tuner module. I think the SAFC is cheaper also, I only paid $265....... |
wouldnt the injectors alow about 15 more hp if the have a flow rate of 10% more? i dont know what you meant when you said (what did you upgrade the injection to?) yes your set up is what was going to get with the turbo but with bigger injectors. the venom 400 module was one of the first things i got on my car, before i knew about all the other things i learned on this site. i was going to keep this set up until i get the turbo kit. when i said i was going to get a turbo down the road, i didnt mention the things i was going to get with the set up. the safc and bigger injectors is some of them. then i will get rid of the venom. do you think the venom is causing some restriction of some kind with my set up? thanks for the advise
