Where to buy a FULL pulley kit
So I have been searching around and can't seem to find a FULL light weight pulley kit (alternator, ps pump, and water pump). I know most company's don't include an underdrive crank pulley in their kits so I don't mind buying that separately, but if someone knows a company that sells all 3 (or even all 4) pulleys in a kit that would be great.
I have no clue, but I would like to ask what lightweight pulleys would do? How do they effect the drive/improve performance?
try your luck with enjukuracing...they have the set of three from greddy/megan racing/circuit sport/Isiss.
reduces rotating mass therefore freeing up some power...not gonna be a whole lotof power but will definatly feel as if the engine revs a lil bit quicker. Hope that helped |
Originally Posted by ug-t
(Post 384829)
(Post 384829)
Originally Posted by shaban
(Post 384830)
So basically; it's like getting a lightweight flywheel?
2 Attachment(s)
well from experience i did notice a small difference on my stock sr didnt cost me much i got the megan ones no color just aluminum $60. they were quite a bit lighter then the stock pullys comparing them.
and also they arnt considered underdrive pullys because they are the same size as stock just lighter underdrive are smaller and cause alot of problems. i do have a OBX under drive crank pully but i never installed it and im selling it because its not worth the risk of installing it for the little performance it gives. now i do recommend the rest of the pullys though. as for KA pullys i dont think ive ever seen light weight KA pullys so i wouldnt know where to buy them ive only seen SR ones Attachment 11269 and the underdrive crank pully Attachment 11270 |
years ago i too looked into getting a pulley set and iirc obx was the only company that made a complete set for the de. many others made them for the sr and a select few made the a crank pulley for the kae. so since there wasn't a set available for my engine i decided buy something else. although i've been told that 2 of the 3 accessory pulleys for the kade will fit the kae.
i got a set of ebay.they were obx..check it out
Originally Posted by Pillion240sx
(Post 385145)
Originally Posted by 240-kid
(Post 385233)
thanks for the help guys |
Sooo.. Where did you find it?
Originally Posted by ilikegofast
(Post 385243)
thanks dude, after a few different searches on ebay (the NST kit doesn't have the ps pump pulley) i FINALLY found a OBX kit that comes with all four pulleys (crank, ps, water pump, and alternator) so i will be picking that up soon.
