where the hell is the thermostat and pcv valve on my ka24e
i tried changing the thermostat today on my 90 s13, and i just couldn't find it
i removed my intake tube so the throttle body was exposed and i had more room, i took off the upper radiator hose and couldn't see anything inside the hole on the engine side, can anyone take a pic of where their thermostat on their ka24e is? i heard it's much easier to find on the ka24de
i also can't find the damn PCV valve, i tried following all the fuel lines that came from the intake manifold and i still couldn't find it, i heard it was under the eccs part of the intake manifold, but it just seems so cluttered inside
the PCV valve has nothing to do with fuel lines... follow all your vacuum lines back from the intake and you should find it. as for the thermo. Im not quite sure cuz i have a DE, but i would imagine it would be not too far after the upper rad. hose.
EDIT: oh wait nevermind about the PCV valve thing... i was thinkin EGR valve... what the hell are you doing looking for the PCV valve anyway??
D Grade
Dec 28, 2005 12:57 AM
change, engine, filter, hose, install, ka24e, location, nissan, pcv, replace, replacement, s13, thermostat, thermostats, valve
