where should the 240sx idle?
My 240 is falling under 1000 rpm, when i first turn it on and then the car turns off. where should the car be idle'n? and how do i adjust this? :dunno:
maybe you shoulda swapped out the auto ecu for a 5speed one :p
when warm, my idle is at like 750
750 @ 160 degrees farenheit.
Car sounds like it has some problems. I know mine is starting up at 30 degrees and I wait until 120 before I start to move. |
such a "wise man" with foolish questions.
you have lots of money to waste. buy a ***ing FSM |
the ecu?
Originally posted by DiZZy maybe you shoulda swapped out the auto ecu for a 5speed one :p |
thanx for the harsh comment cool guy
Originally posted by rudeboy such a "wise man" with foolish questions. you have lots of money to waste. buy a ***ing FSM |
Re: the ecu?
Originally posted by DCTperformance It could be that, but this used to happen even with the auto tranny, so i think it could be something else. any way to adjust the idle point? :spin: |
Re: thanx for the harsh comment cool guy
Originally posted by DCTperformance you must get alot of respect around here? (lol) keep up the good work cool guy. :cool: I respect him.....:thumb: |
did you get the FSM yet?
the 240 should idle at 1000rpm when its cold, and 750rpm when warm...straight out of the service manuel that nissan uses
700 +/- 50rpms when warm.
Originally posted by twisted_240 the 240 should idle at 1000rpm when its cold, and 750rpm when warm...straight out of the service manuel that nissan uses mine idles at like 1500-1600 when i start it up. its like 10 degrees outside or something tho. |
