wont start..
well to hear that click you must be out in the bay.. but you should hear the fuel pump prime.
however if your turning the key and you are getting no cranking, check your starter and your fuses make sure all of your grounds are secure mainly the ground on the intake manifold.
see this is hard man.. you did way to much at one time.... for your first time doing it.
there is a big black with yellow or red stripe wire that should be going from the chassis ( right under where the battery use to be ) to the intake manifold right to the left and down of the throttle body.
how did you run the battery relocation.
