Ca18det Upgraded Complete Motorset, located in TX
Motor Was just pulled yesterday, and put in storage.You will need the ecu to be chipped, since there is an bigger turbo and injectors. Or you could just use an safc2 to compensate for the upgrades. The harness can be wired up for an s13 240sx, for no additional charge if you would like.
-Ca18det w/ 29,XXX miles on it -Perfect compression amongst all cylinders, no lifter nosie, or rod knock. Very strong, good running motor. -Sr20det t25g Blacktop turbo (35,000 miles on it, perfect condition) -Upgraded 450cc Sard injectors -HRS 160* Thermostat -Metal HG -Metal Exhaust Mani Gasket -New Slave Cylinder on tranny -Tranny and engine still bolted together -Majority of gaskets replaced Newer Parts just bought: -Ca18det harness -Ca18det ECU -Ca18det newer Coilpacks -Ca18det Ignitor -Ca18det CAS -Ca18det Dropping Resistor -Ca18det MAF I paid $1350 for the motorset without harness or ecu. The sard 450cc injectors, and the t25g from an sr20det blacktop were an additional $375. The new harness, and coilpacks with ignitor were $450 shipped from japan 2 weeks ago. The replaced gaskets,hoses, and thermostat were around $100. Im asking $2000 picked up for the complete motorset. With all of the upgrades this car will put down around 220-240hp to the rear wheels. It will be able to beat quite a few cars including slightly modded sr20det swapped s13's. The engine was taken very good care of by its original japanese owner, and by me. MANY things have been replaced and are very nice. Sure this motorset is a little more expensive than other CA motorsets, but look at it this way, it already has good upgrades, you know for a fact it runs perfect, you know for a fact it has a complete engine harness(rare on CA motorsets to find these if you dont have one to begin with), you know for an fact is has good compression, and has not been abused, and many things that you have to swap out and replace when you get a motorset have already been done so you wont have to worry about them later on. EMAIL: trackrules69@gmail.com Im located in azle, TX 76020 pics of the motorset: newturbo- http://i36.photobucket.com/albums/e6...29-06_1138.jpg enginebay- http://i36.photobucket.com/albums/e6...t/FL000023.jpg engine bay 2- http://i36.photobucket.com/albums/e6...et/May2510.jpg engine bay 3- http://i36.photobucket.com/albums/e6...et/May2504.jpg engine bay 4- http://i36.photobucket.com/albums/e6...27-06_0019.jpg |
