SOLD: kyo-ei 50mm extended hub bolts
Got these kyoei wheel studs from projectnissan.com to use on my STi. Unfortunately the knurled area is literally a hair too small in diameter to form a solid fit, so it doesn't look like they are going to work on the Subaru. I have ten of them, none have been pressed into the hub (I bought 11 and used one for the test-fit.)
They are an alternative to the NISMO studs and are supposed to be a higher quality part. kyo-ei hub bolts at projectnissan.com SOLD. Please email my username at gmail.com if interested since I don't really spend much time on the Nissan boards :) http://premium1.uploadit.org/austinp...oei-bolt-1.jpg http://premium1.uploadit.org/austinp...oei-bolt-2.jpg should fit as follows: 1990-1996 300ZX - front axle 1995-1998 240SX - front axle 1991-1994 Sentra - front and rear axle 1995-1999 Sentra - front and rear axle 2000-2004 Sentra 2002-2004 Altima 350Z |
bump for the hub bolts.
so those won't fit an 89 240?
^^^ I am thinking you would need the ones with the 13mm knurl diameter (these are 14.2mm) - don't know for sure. You would have to call projectnissan and check.
b u m p
still got 'em...
anyone for $25 shipped?
try again...
SOLD |
