-   Private For Sale / Wanted (https://www.s-chassis.com/forums/private-sale-wanted-18/)
-   -   sr20det redtop engine,tranny,harness (https://www.s-chassis.com/forums/private-sale-wanted-18/sr20det-redtop-engine-tranny-harness-37501/)
Juiced Feb 20, 2007 08:54 PM
ABSOLUTLY NO PARTING OR SHIPPING.
ok what i have here is a redtop sr20det with 55k miles. motor is all stock. stock t25 with some shaft play but boosted and worked fine when i had it. what it needs is main crank\rod bearings. motor knocks very little. i drove it for 1 month like that and took it easy before i bought another sr20. compression on the motor is 155 on all 4. i also have a good 5spd tranny, flywheel, decent clutch. i have wire harness also but might be missing the plug to the maf sensor. also i think i have lower harness to go with it.
well all in all im only askin $1000 firm for all this stuff since it only needs crank\rod bearings since they are only $200 for the set. the motor still ran perfect other then the slight knockin between 2-3k rpm.
im located in south jersey,vineland.
RB20s13coupe Feb 25, 2007 07:45 PM
Is it a complete swap? If so, Im interested!
Juiced Mar 4, 2007 08:08 AM
what u need is a ecu,ignitor,maf sensor, and i belive thats it
