maf on my rb26?
Can I run a single maf on my rb26? I have head that a 300zx maf will work. I just dont like running two mafs because the intake looks like ****. It is a Y pipe intake and it is ugly and takes up too much space. thanks for any help
I think if you get a stand alone fuel management system, you can switch to MAP. It will go somewhere after the turbo and before the throttle.
as smoke said if you switch to a map sensor its possible to run no maf. if your running a single turbo i would keep the twin maf's because if you try to use only one it might freak out a bit because of all the air and voltage being shoved into 1 as opposed to 2. just switch to a map
Ok, I guess I will stick with the dual setup for now. Thanks for the help fellas
you should go with Map then.
