n00b to club240.
What are you looking to dow ith the car? What kind of motorsports, DD(daily driving?)?
For drag racing, the RB25 will be the best choice. SR20 is a good overall engine. If i had the money id probably go for the RB25.
again, this type of question (should i get engine A or engine B?), presented in this matter is extremely vague. specifics, man. it's all about the specifics:
- what do u wanna do w/the car (motorsports, show, what)?
**if motorsports, what kind and will weight balance be a factor?
- what does ur budget look like?
- how much downtime can u afford?
- doing it urself, or taking it to a shop?
- concerned about stock parts avaliability?
- what about aftermarket?
- does it need to be smog legal (methinks fmax or somebody makes a CARB legal turbo kit for the KA)?
- which one do u just plain LIKE?
ask a better question, get a better answer.
thanks sil40....i see what you mean...lol...i was thinking about a daily driver plus a little drifting/autocros. something i can run the little hondas into the ground with.
do you guys know if the SR20DET will pas a smog?
if ur not going for the hardcore track setup, this should suit ur needs:brakes
- good solid (non-slotted, non-drilled) rotors (think Brembo)
- dot 5 brake fluid
- SS braided brake lines
- good brake pads (Axxis comes to mind)
suspension
- good shock/spring combo (search for recommendations)
- upgraded sway bars
- strut tower braces (front and rear)
drivetrain
- some form of LSD (VLSD, clutch type, helical, etc)
as for power, again, that depends on preference, budget, knowledge, etc. u can do an N/A buildup, turbo the stock motor, or go for a swap. my best advice is to thoroughly research each option and see which is the most viable for ur situation.
as far as beginning/occasional drift sessions, what u have right now is good enough (if it's running, that is). that's right, stock. bone stock.
oh, and seriously, consider searching more. look what i pulled up using "pass AND smog" in the query:
http://www.club240.com/forums/search...der=descending
while a lot of flaming doesn't go on here, members do get tired of repetitive, easily researched questions.
Welcome to the site!
