newbie just saying hi
hey fellas. i just thought id say hi. i guess im still sorta new. anyway here is what i got:
91 240sx se hatchback, black sr20det (swap in progress) greddy pulleys z32 mafs apexi filter garrett gt25r 3" dp, o2 ext., 3" test pipe rsr ex mag exhaust nismo motor mounts, tranny mounts, pivot, braided slave cylinder line, high pressure radiator cap spec flywheel and clutch kit apexi multi-checker turbo xs dual stage boost controller arc bov hks actuator ( for turbo) skyline r33 lsd east bear subframe bushings koyo radiator and flex a lite fan searco bar and plate intercooler pilot shifter and greddy counterweighted shift knob |
:wave:Welcome to the forums. Got any pics of the car? ;)
no it needs some body work first. ill take pics when i get further along. right now ive just been buying stuff and doing block assembly. ive replaced all old parts with new ones such as water pump, oil pump, belts, timing chain, spark plugs, thermostat. stuff like that. i got bigger injectors, custom fuel rail and an aeromotive fuel press. reg. along with a nismo thermostat.
welcome.:wave: sounds like u got a hell of a project in the making. keep us posted.:thumb:
i got the engine in. hooked up most of the stuff. i just need the lower chassis tranny wiring harness.
WELCOME to the forums!!:thumb:
welcom to the greatest 240 forums lol. :wave:
Its "DICK HEAD FREE" here:D |
Hiyo and welcome :wave:
hi everyone thanks for the welcome. my car is almost done engine wise. then ill be moving on to the suspension and brakes.
did you notice the difference when you put on the greddy pulleys ?:D
its not running yet i need to get the lower tranny harness. i also need ic piping and i need to get off my butt and make some turbo lines. then ill be ready to go.
how much have you put into your car alwready??:dunno:
ive put so much into my car wayne and howard from phase2 know me really well now. its a bottomless pit. i still need stuff, like an exhaust, ic piping, turbo lines, suspension, brakes, etc...
sweet!!:D
dang.. comin up with the quickness.. and WELCOME!! TO THE WORLD OF TOMORROWWW!!! 'lightning and thunder in the background'
