rear main seal housing torque spec
hello, I'm doing a rear main seal on my 91 ka 240 and I'm looking for the torque spec on the bolts going into the block and the 2 from the oil pan underneith, does anyone have this?
most click style torque wrenches i've seen have a tolerance of +/- 4% and needle type wrenches are at about 2% iirc, so i'd just torque everything to 30ft-lbs and call it good.
dude that would snap it of it 2 sec, the spec is going to be in inch pounds
ok, in that case torque them to 360in-lbs.
but seriously, for some reason i thought you were talking about the bell housing specs. the bolts you are asking about should be torqued from 4.7 to 5.5ft lbs |
