having trouble
Ok so I finally got around to working on the car and I can't get it to runright.
When not moving the car idle and revs fine, but under load it breaks up nasty. It won't rev past 3k and you can hear it spooling but its not going anywhere My setup is Sr mani modded for ka S13 t25 370cc injectors Stock maf(blow through) Stock fuel pump Sidemount Tial 38mm(atmospheric) 3 inch down pipe Safc1 settings -27 across all low throttle ne points -17 across all high throttle ne points 5in 5out maf settings (the only way it will ildle) Throttle is 10% and 45% I just need the car to run to get me to and from work untill I can get on a dyno and change the maf and fuel pump. Help please and thank you |
| All times are GMT -7. The time now is 12:07 AM. |
