****SR20DET Z32 Brakes silvia front end
Please call me only im on so may forums it gets confusing 704-746-4468 Alex
everything listed can be shipped if you pay shipping unless we work a deal other wise I have lots of parts black interior parts if you want some call me and we can work something out Z32 50mm calipers front and rear and e brake assembly with skyline rotors $600 J30 Vlsd $250 Silvia Front end coversion Fenders hood bumper triple projectors corner lens and silvia center peice $950 S13 cluster with heads up display $100 Silvia Rear truck lock $60 Toyota CT26 (mk3 supra) turbo Rebuilt $250 All S13 SR20DET parts Redtop Short Block $450 Bear head $200 Valve cover (custom purple) $150 Stock intake and exhaust cams $100 Stock Cam gears $10 Valve $40 Valve Spring $50 Intake Mainfold $100 Coolent Tube $10 Front timing cover $70 Cam shaft caps $50 Pistons and rings $80 Crank shaft $120 Rear cover $15 Flywheel bolt $20 Lower Oil pan (perfect still has sticker) $40 Upper oil Pan $90 Alt. $60 A/c Pump with bracket $110 S13 Seats black with no rips one peice seats $100 #62 ecu $100 Full wireing harness $280 trans $150 4 teardrop wheels with tires $100 S13 Hood $50 S13 hatch taillights $90 turn signals $10 Lower grills $10 Radiator $20 Downpipe $20 2 sohc maf $20 a peice 1 dohc maf $50 |
bump thread
how much for the A/C bracket?
