s2kguy17 |
06-21-2009 10:10 AM |
fs: ka24det,megan streets coils,roof wing,apexi catback
4 Attachment(s)
Ok so i am going to sell my ka24det seperate from the car..$1500 obo bottom shows what your getting im not taking it apart everything goes..also got my roof wing $70..almost new megan street coilovers $600 plus stocks and my apexi 3inch catback $200 has dent on pipe by axels but doesnt leak still really good..
no pics of the coils there still on the car but i can assure you they look and ride like new..
KA24det-ill post my thread from when the motor was built..new factory pistons 10 over,new piston rods,new rod bearings,new crank bearinig..engine was clean out at machine shop and dipped..crank was balanced and polished..new oil squirters..all new gaskets..new head gasket/stock..had a cometic sold it..the head is stock also just cleaned it and resurface the valves timing chain is stock stiff still..engine is in timing and read to go..still needs some hoses/etc t25 turbo tiny bit shaft play wont even hurt it good miles..megan header..solid motor mounts all new bolts on motor...intake vac deleted 370cc sr injectors comes with harness rewrapped in tape..2 ecus..also have the tranny in a box needs to be cleaned no grinds..3 inch down pipe/test pipe...skyline front mount top fuel bov...apeci n1 cat back..
pick up only
http://www.tamparacing.com/forums/ni...i-catback.html
