S14 Sr20det Engine, PTE5857 BB Turbo, Mazworx VG to SR, Wolf 3d Standalone ecu Plug..
4 Attachment(s)
Engine S14 SR20DET Variable valve timing system Brand New Block 6,000 Miles ARP Head Studs Power Enterprise Head Gasket with Fire Rings Block Rehoned Valves Reseated Engine Ported Crank Journals Polished ACL Race Bearings Forged JE Pistons Eagle Rods Tomei 270 Solid Lift Cams HKS Lash Killer Kit Brian Crower Springs and Retainers Sr20det Steel Flywheel Resurfaced Greddy Oil Catch Can Monkey Magic Engine Mounts Uras CAS Guard Cap Uras Oil cooling Block Remote oil Filter Relocation Kit Brand New Oil Pump Brand New Water Pump New Timing Chain kit Greddy Pully Kit Power Enterprise Power Steering and Main Belt Engine- $3000 Wolf Stand Alone Engine Management System , Plug & Play (car is tuned for 93 Octane, I also have an E-85 Map) with 5 Bar map sensor $ 800 Zenki Engine Harness Wiring Done by Wiring Specialties Yuri- $250 Full Race Tubular Pro Race Manifold (Life Time Warranty full race) Full race down pipe 3 inch- $800 Precision Dual Billet Wheel Ball Bearing Turbo 5857 Ported Surge Housing Rated at 605hp, .63 A/R, Just brought last month...- $1000 Front Mount Intercooler Kit 3 in- make offer Tial Blow Off Valve 50 MM- $160 Tial 44 MM Wastegate 18 PSI spring- $250 Split Fire Direct Ignition Coil Packs W/ Amplifier - $280 Circuit Sports Grounding Plate- make offer Auto Meter Boost, Oil Pressure, and Air Fuel Gauge, Battery, Water Temp, Oil Temp, AEM Air Fuel- Make off Greddy Intake Manifold Generation 2 (1 Piece Manifold not 2) with Fuel Rail for Top Feed Injectors and 90mm throttle body- $900 Greddy Type S boost Controller- $250 Greddy Turbo Timer- make offer Mazworx VG to SR Conversion Kit with 300zx Transmission $ 900 ACT Unsprung Clutch $200 Email me: Darryl.Fontaine@gmail.com located in Brooklyn, NY. Any questions, call me at 917-873-5415 Shoot me Offers... |
S14 Sr20det Engine for $2000. S14 & S15 Greedy intake manifold 2nd Generation with 90mm throttle body, and fuel rail for top feed injectors $800 .....Wolf EMS Standalone with hand controller and memory card.. $ 700
Greedy intake manifold with Throttle body, Fuel rail, and Full race manifold setup- sold. Still have the ball bearing PTE5857 billet turbo (605hp) for sale $1000, Engine for $2000, and Mazworx transmission kit with Transmission for $900
Transmission kit sold.
Wolf sold.. Splitfire ignition Sold... I still have a s14 sr20det engine built.. For $2000 I have a Precision Turbo that is two months old with low miles..PTE5857 Dual Ball Bearing Billet Wheel Turbo for $1000.. Tial BOV 50 mm $160 Tial 44 mm wastegate $250 Act unsprung Clutch $200 Greddy Type S boost Controler $250 Please shoot me offers! |
http://cgi.ebay.com/ebaymotors/S14-S...item415d2a8a18
S14 SR20DET * http://cgi.ebay.com/ebaymotors/Preci...item415d2a67da PTE5857BB Turbo |
Only thing left is Tial 44 mm waste gate and engine harness
