SW MO: FS: 180sx Black Top SR (disassembled) and more...
Please READ all of the description...
NOTE: werid looking dust like stuff in the photos is saw dust...
Photos Can Be Found here
I need to clear out my garage before I start on the next motor swap. Stuff has to go!
180sx Black Top SR20det...It is disassembled and will need a cylinder 4 rod, new set of bearings and gaskets. Pistons and wrist pins are fine, head is dirty but ran awesome. New "style" timing chain tentioner. It ran perfectly with the bent rod. The problem with the motor was a messed up pressure plate, which was causing noise so I took everything apart. Crank, cams, etc look perfect.
Motor was sold to me with an estimated 32k miles on it from SR20Store.com for $2,100 plus shipping 5 years ago. I'll be honest, the motor wasn't babied, not in the least. I've only put 4k-5k more miles on it since I hardly ever drove the car. Was averaging 25 mpg and that generally included 1-2 race days on a tank of gas.
---with it you get---
180sx Black Top (not red top painted black) Engine (disassembled)
180sx 5-Speed Transmission
Flywheel
SR to S13 Harness
S13 ECU
Megan Racing bottom mount Manifold
RS*R Downpipe
2xNice plastic containers will all bolts, nuts, etc from motor. **LABELED!**
NO A/C Pump (Might be able to locate it, if you really want it)
Basically anything included in a swap package but it's in pieces.
Would need new clutch and pressure plate...
$800.00
---Also Up---
Greddy FMIC with full piping (for bottom mount, has greddy bov flange welded on) $150.00
Greddy RS BOV (perfect condition) $100.00
Vented hood that fits 240sx with the above parts, piping holes cut into hood. $120.00
---Shipping---
Pick up or arrange your own shipping, sorry but there is to much here to try to box up.
Flywheel
SR to S13 Harness
S13 ECU
RS*R Downpipe
$800.00
---Also Up---
---Shipping---
ErnGotti
Feb 12, 2011 04:16 PM
