HPF GB Brian Crower blow out!!
[b]Brian Crower http://www.briancrower.com/images/200x200.gif Group Buy for 240SX provided by HorsepowerFreaks http://www.horsepowerfreaks.com/publ...ka24de-pic.jpg The 2.4 L (2389 cc) KA24DE was used in many Nissan cars and trucks. Most KA24DEs bound for the US were built in Aguascalientes, Mexico, with the exception of the 240SX, which was manufactured in ***uoka, Japan. The Nissan 240SX was a car introduced to the North American market by Nissan in 1989 and sold there until 1998. It replaced the 200SX (RWD) in 1989. The 240SX was equipped with a 2.4-litre inline 4 engine (KA24E from 1989-1990 and KA24DE from 1991-1998). Two distinct generations of the 240SX, the S13 (1989-1994) and the S14 (1995-1998), were produced from the Nissan S platform. The 240SX is closely related to other S vehicles: the Japanese-market Silvia and 180SX and the European/Australian-market 200SX. Many enthusiasts are turbocharging, creating the KA24DE(T) engine code. http://www.horsepowerfreaks.com/publ...ms_Stage_3.jpg STAGE 3 Race Specification Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires kit BC0210. V3 Specification. May require mild cylinder head clearancing BC0212 Cam # Adv. Dur. Dur @ .050 Lift (in) Lift (mm) Kit # 114° 272°/272° 226°/226° .401"/.401" 10.19/10.19 BC0210 USDM Stock 256°/256° 203°/207° .344"/.357" 8.73/9.06 ----------------$270 shipped---------------- http://www.briancrower.com/makes/toy...24v1retkit.jpg VALVE SPRING/RETAINER KIT Designed for high rpm, BC valve springs are wound from only the highest grade, super clean, chrome silicone alloy and feature proprietary processing procedures for consistent pressures. BC retainers and spring seats are CNC machined from 6AL4V titanium to exacting tolerances. Kit # Spring # Retainer # Seat # Description BC0210 BC1010 BC2210 BC4210 Dual spring, titanium retainer/seat Spring Pressure: BC1010 Seat: 1.400" @ 73 lbs / Open: 0.950" @ 155 lbs / Coil Bind: 0.850" (no machine work required) Maximum lift on stock valve springs is .380". ----------------$339 shipped----------------- http://www.briancrower.com/makes/dodge/images/rod.jpg PRO SERIES 4340 STEEL BILLET RODS Built from rugged 4340 billet steel, BC Pro Series rods for the Nissan KA24DE are designed for high horsepower forced induction engines as well as high rpm normally aspirated applications. Features ARP 220,000 p.s.i. bolts and aluminum bronze bushings. Rod # C-To-C BE Bore BE Width PE Bore PE Width BC6219 6.495" 2.086" 0.973 0.827" 1.000" -----------------$622 shipped------------------ http://www.briancrower.com/makes/toy...s/24valves.jpg STAINLESS STEEL VALVES BC valves are made from premium stainless steel, fully machined and swirl polished for ultimate air flow. Dished head for added weight savings and increased valve control at high rpm. Oversize head diameter only Part # Description # BC3210 37.10mm Intake (+.5mm head diameter) ------$119 shipped----- BC3211 31.80mm Exhaust (+.5mm head diameter)------$120 shipped----- http://www.horsepowerfreaks.com/publ...CP_PISTONS.jpg 89MM BORE 9:0:1 COMPRESSION - High strength aluminum forgings.<BR> - Super lightweight designs.<BR> - Fully CNC machined and balanced to +/- 1 gram.<BR> - Wrist Pins included at no extra cost.<BR> - Accumulator groove included.<BR> - Double pin oilers, force fed from oil ring.<BR> - Pick lock grooves for easy lock removal. ------------------------$485 shipped------------------------ This group buy is for 10 of each item, once those ten are sold and everything is paid in full then we will ship. CAMS- 1) VALVE SPRINGS/RETAINERS- 1) RODS- 1) INTAKE VALVES- 1) EXHAUST VALVES- 1) PISTONS- 1) |
