-   'For Sale' Engine / Power and Drivetrain (https://www.s-chassis.com/forums/sale-engine-power-drivetrain-67/)
-   -   jdm r33 Gts-T rb25det swap f/s (https://www.s-chassis.com/forums/sale-engine-power-drivetrain-67/jdm-r33-gts-t-rb25det-swap-f-s-5438/)
racer98 Aug 16, 2003 11:42 AM
1 Attachment(s)
JDM r33 skyline gts RB25DET (280hp) R33 Skyline motor swap for sale complete also has ceramic turbo complete change Complete motor with turbo, original full harness, ECU, mfs, cas, 5-speed gear box with drive shaft from original Z31 200zx~R flywheel, used clutch, starter, alternator non-hicas power steering pump over a/c and lines also have harness diagram pin outs from an English service manual for the RB25DET for a swap over into a us-spec s13 or S14 also this motor comes with the Z31 200zx~R skyline oil pan and the motor mounts and crossmember. $3500 Compression is 170psi on both motors and leak down is 5 f you need more info give me a call (818)-345-7289
Mr.Apple Aug 22, 2003 07:48 AM
Where are you located>?
rudeboy Aug 22, 2003 11:59 AM
info like that usually helps
Mr.Apple Aug 25, 2003 12:39 PM
Where you at Racer98??
runyun Aug 25, 2003 01:37 PM
He's in Encino, California - I believe by Burbank.
runyun Aug 25, 2003 01:43 PM
BTW - if you plan on buying from him, make sure it's in stock.
other than that - his motor's are of SUPER quality. Even the panels I received looked brand spankin new.
If the fenders I got didn't have the stock sidemarkers on them.. I would honestly have thought they were brand new from the dealer.
NightXCZ77 Sep 1, 2003 03:51 AM
RB25DET only has 250 hp, not 280...just thought I'd put that in.
Night
Driftin RPS13 Sep 1, 2003 05:04 PM
is that 3500 shipped? if not how much would shipping be to Green Bay WI 54301? i am very interested!!!!!!
runyun Sep 5, 2003 08:00 AM
NightXCZ77,
You're the guy people are talking about in this post right?
http://www.nissaninfiniticlub.net/fo...threadid=26728
if so, you've made a lot of people upset
