Defi Red Racer and White Racer Gauges IN STOCK @ 201 Motorsports
Defi Red Racer and White Racer Gauges @ 201 Motorsports
No Control Unit Needed!!!
Exclusive gauges for the USA which are derived from quick-responsive and high-accurate Defi analog gauges.
* Stepping motor "STEP MASTER VS-2" provides smooth operation
* Ignition ON initiates self-luminescence gauge
* Red illumination using high-brightness LEDs
* Full 270 degrees sweep dial provides ultimate visibility
* A mounting bracket and instrument case is provided with the product
* The red triangle of the regular position bezel can be used as a warning indicator
* Does not require the Defi-Link Control Unit for use (Blue Racer Gauge cannot be connected to the Defi-Link System)
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Sensor disconnection check:
This function reports any in-proper connections, broken or disconnected sensor or sensor wire. The pointer will wave between 250 and 260 degrees.
Short-circuiting check:
This function indicates any short circuit on the sensor or sensor wire.
Defi Red Racer 52mm Gauges
Boost: $170 shipped
EGT: $200 shipped
Pressure: $200 shipped
Temperature: $145 shipped
Defi White Racer 52mm Gauges
Boost: $170 shipped
EGT: $200 shipped
201Motorsports
42
Aug 18, 2008 11:02 AM
201Motorsports
Jan 26, 2008 01:05 PM
201Motorsports
Jan 22, 2008 07:44 AM
201Motorsports
Jun 8, 2007 12:12 PM
201Motorsports
Apr 12, 2007 12:04 PM
