FS: New S13 Megan Street serious and s13 Ksport Kontrol Pro Coilovers
Im locate in SoCal, I have 2 sets of coilover for sale
Both are Brand New taken out the box for picture only!!!! 1) Megan Street Serious Coilover kit for s13 Brand New Local pick-up 780, 820 shipped (paypal or money order) If paying with Payapl must be Comfirmed Address!!! ONLY ship the item to Comfirmed Address Spring Rates: 8kg Front and 6kg Rear 32 Levels of Adjustable Damper Pillow Ball Upper Mounts. Rubber Dust Covers. Adjustable Ride Height Aggressive Spring Rates Single-Cylinder Design Aluminum Brackets 2) Ksport Kontrol Pro Coilover Kits for S13 Brand New Local pick-up 750, 800 shipped (paypal or money order) If paying with Payapl must be Comfirmed Address!!! ONLY ship the item to Comfirmed Address SPRING RATES: Front-7/392 Rear-6/336 Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology featuring its 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance. Ksport Kontrol Pro Coilovers Feature: - 36-way adjustable dampening - Made from high quality 6061 Aluminum with T6 for increased hardness - Compression/Rebound adjustable - Adjustable spring perch for height adjustment - Adjustable body allowing maximum suspension travel - Pillow Ball Top Mount w/ adjustable camber (not available for some models) - Monotube High Pressure Design reduces oil leakage - Electroplated body for protection from corrosion and rust - One Year Limited Warranty http://i37.photobucket.com/albums/e8...1/af7895fc.jpg http://i37.photobucket.com/albums/e89/pl91741/002.jpg Need more info on the coilover please ask, also if you need more picture i can prove thank you. |
pump....!!! Need them gone!!
god i want these
too bad cashflow is not up to par free bump!!! |
Are theese fit to S14 95or 96?
If so, Give me a call 310-254-6803 Hiro |
negatory. s13 fronts will fit on an s14 only if you enlarge the diameter of the hole for the bolts to pass through for them to bolt onto the spindle. the rears of an s13 are taller than that of an s14.
bump. I'll see if my buddy has funds for a set of these coilovers |
Megan Street Serious Coilover kit |
series,
you cant be that clueless. |
