**Megan Racing Suspension ** Big Sale**
**MEGAN RACING** CALL ME!! 407-352-7024 (Adam) COIL-OVERS Their Price 1050.00 per set MY PRICE !!! 976.00 per set Nissan 240SX 89-94 S13 Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications. The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills. The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities. Features: - Spring Rates: 8kg Front and 6kg Rear - 32 Levels of Adjustable Damper - Pillow Ball Upper Mounts. - Rubber Dust Covers. - Adjustable Ride Height - Aggressive Spring Rates - Single-Cylinder Design - Aluminum Brackets 32 Levels of Adjustment: 1-8: Suggested for track use. 9-16: Suggested for mountain/aggressive use. 17-32: Suggested for common street use. - All coilover damper kits come with 1 year manufacture-defect warranty. - All Hardware is Included http://www.meganracing.com/uploadIma...0II%20x500.jpg http://www.meganracing.com/uploadIma...r/DSC00347.JPG http://www.meganracing.com/uploadIma...20V%20x500.jpg Nissan 240sx 89-98 One-Piece Race Spec Strut Tower Bar Their Price $99.95 MY PRICE $93.00 One-Piece Race Spec Strut Tower Bar constructed of strong Aluminum to extremely tight tolerances and then polished to perfection. Designed for the Impreza to decrease body roll, this bar ties the chassis from left to right at critical stress points (Between the shock/strut towers). As you drive and maneuver, your car undergoes many different forces that the chassis of the car absorbs; the brace helps to absorb the energy and directs these forces into your suspension components so that they can better do their job and serve their purpose more effectively. Megan Racing emblem is included Nissan 240SX 95-98 S14 MEGAN LOWERING SPRINGS Their Price $169.95 MY PRICE $130.00 Megan Racing Performance Lowering Springs are constructed of SAE 9254 Cold Wounded Steel, one of the strongest materials available. The high tensile strength and phosphate powder coating delivers outstanding spring rates that are extremely durable and resist premature “sagging”. The result is a spring that specifically offers racecar handling, yet maintains smooth and comfortable ride characteristics. Carefully matched springs rates provide exceptional handling, response, control and balance. These springs offer a generous drop to your car while remaining very “streetable” by having enough clearance to avoid bottoming-out; and the lowered center of gravity improves performance and increases stability, as well as enhancing the appearance of the vehicle. (Note: Spring rates and drop amount vary by different vehicle application and chassis load.) Spec: - Color: Orange - Lower rate: 1.75" Front+Rear - Springs rate: 350F & 250R Nissan 240SX 89-94 S13 Front Upper Strut Tower Bars Their Price $69.95 MY PRICE $65.00 The Megan Racing Strut Bar ties the strut towers together in order to get out the most from your suspension to improve handling and stability. We also make front lower tie bar, rear upper bar and rear lower tie bar for some models. Each strut bar is constructed from CNC machined 6061 billet aluminum, very strong and last very long. Special unique style and the 1.75” width with 0.75” thick bar make them stand out even more. - 4 colors available, BLUE, RED, POLISH AND GUNMETAL - 1 Year limited warranty Nissan 240sx 89-94 Rear Lower Toe Arms Adj. Suspension Arms/Rods Their Price!! $118.00 MY PRICE !! $109.00 The 240SX/Silvia is an amazing platform in all it s generations. The FR-Drivetrain and it s light weight offer a perfect balance between speed and agility. Used in a wide range of motorsports such as drag, drift, autocross, road race and even rally the 240SX has proven it s worth time and time again. Those who seek the most from their car know that in the rigors of competition you need to extract every ounce of performance from your machine. You need the capability to have every degree of adjustment above and beyond that of a street driven vehicle. You need the strength to withstands the stresses and strains of hard corners, a rough course and brutal weight transfer and chassis flex. It s within this understanding that Megan Racing has unveiled our line of reinforced suspension arms that offer the strength and adjustment that any comptition vehicle will ever need. Constructed of high-strength steel alloys that offer durability, strength and yet remain light-weight, these control arms have been track tested for months in road race, autocross and drift events to assure quality and performance. These Rear-Lower Toe arms available for the S13 and S14 chassis are an excellent upgrade. With it s adjustability you are able to carefully tune the vehicle s Rear-Toe to your specifications. The pillowball ends replace the stock rubber bushings on the chassis and offers you a more direct and predictable feel that you require in competition. With proper adjustment will allow the adjustment of proper toe which can greatly effect tire wear and the stability of the straight line and cornering of the vehicle. The adjustability and feel is also backed with the comfort that your stock thin tension rods are now replaced with thick steel contstructed arms that can withstand the stresses of competition. - Adjustable lengths to tune Rear-Toe - Pillowball bearing replaces OEM rubber bushing. - Durable Steel construction to withstand high-stresses of competition. - Powdercoated with brilliant blue finish for years of performance. Nissan 240sx 89-94 Rear Upper Control Arms Their Price $160.00 MY PRICE $148.00 The 240SX/Silvia is an amazing platform in all it s generations. The FR-Drivetrain and it s light weight offer a perfect balance between speed and agility. Used in a wide range of motorsports such as drag, drift, autocross, road race and even rally the 240SX has proven it s worth time and time again. As a street car, it s refined and well mannered, comfortable to drive in and stylish with a bit of aggression in it s curves. Although it s initial design was sporty and aggressive it was still designed as a street car. Those who seek the most from their car know that in the rigors of competition you need to extract every ounce of performance from your machine. You need the capability to have every degree of adjustment above and beyond that of a street driven vehicle. You need the strength to withstands the stresses and strains of hard corners, a rough course and brutal weight transfer and chassis flex. It s within this understanding that Megan Racing has unveiled our line of reinforced suspension arms that offer the strength and adjustment that any comptition vehicle will ever need. Constructed of high-strength steel alloys that offer durability, strength and yet remain light-weight, these control arms have been track tested for months in road race, autocross and drift events to assure quality and performance. - Adjustable lengths to tune Rear-Camber - Pillowball bearing replaces OEM rubber bushing. - Durable Steel construction to withstand high-stresses of competition. - Powdercoated with brilliant blue finish for years of performance. Nissan S13/S14 Rear Lower Support Bar Their Price $75.00 MY PRICE $69.00 Nissan S13/S14 Rear Lower Traction Rods Their Price $118.00 MY PRICE $109.00 Nissan 95-98 S14 Tension Rod Support Bar Their Price$75.00 MY PRICE $69.00 [CENTER]http://www.meganracing.com/uploadIma...0supportx8.jpg |
Nice prices keep up the good work!!
