Lug Nuts In Stock @ 201 Motorsports
Lug Nuts @ 201 Motorsports Muteki Lightweight Short Lug Nuts (Closed End & Open End) http://www.201motorsports.com/images...d_end_lugs.jpg The Muteki Wheel Lugs are shaped in a heptagonal pattern making each a seven sided lug nut. Muteki nuts look like an ordinary lug nut from a distance, but the only way that you can remove the Muteki lugs is with the special socket ONLY provided with the set. You'll get added security for your rims. The Muteki lugs also weigh 50% less than stock lug nuts (0.9 oz. vs. 2.1 oz.) On a car with 4 Muteki lugs per wheel, this can save you more than a pound! These Muteki lug nuts are open ended to comply with most race sanctioning bodies and can be used for everyday driving. Muteki Lightweight Open End Extended SR48 Lug Nuts http://www.201motorsports.com/images/P/sr48-sm.jpg The latest lug nuts from Wheelmate of Japan, the SR48 Lug Nuts come in a set of 20 with key adapter. Made of durable chrome vanadium, each lug weighs in at a mere 2 oz! They're also open ended, making them easily adaptable for short or extended wheel stud usage. Muteki Lightweight Open End Extended SR48 Lug Nuts (Neo Chrono) http://www.201motorsports.com/images...neo_chrono.jpg The latest lug nuts from Wheelmate of Japan, the Muteki SR48 Lug Nuts come in a set of 20 with key adapter. Made of durable chrome vanadium, each lug weighs in at a mere 2 oz! They're also open ended, making them easily adaptable for short or extended wheel stud usage. Super light-weight thin-wall contruction using strong CHROME VANADIUM 28DCRVM SPEC. Work Lightweight Closed End Duranium Short Lug Nuts http://www.201motorsports.com/images...k-lg-short.jpg WORK Light Weight Racing Lug Nuts. Make by Duranium material. Extremely light weight. Come in 20 pieces per set including 4 locking nuts. Available in M12 x 1.25 or M12 x 1.5 Available in Red or Blue Only |
Do you have the Muteki open end short lug nuts? If you do how much for those?
Also, do you carry 50 mm extended wheel studs from either Peak or Ichiba for S14 5lug? |
Yup, I have all of the colors (blue, red, black, and chrome) in stock for the open ended short lugs as well :) The price is $45 shipped.
I don't carry the extended wheel studs though, I'm sorry :( |
I will definitely hit you up end of this week for the lug nuts, but boo for not having extended studs! LOL
I guess I'll just keep looking for the studs, I was just hoping that I could kill 2 birds with one stone so to speak. |
(Post 359358)
SWEET! Let me know whats up. If you can get a deal on the studs as well, I'll pick up both from you at the same time!
(Post 359774)
You got a FRIKIN SWEET DEAL!
So my other question is, on the knurl section of the stud, one is 14mm, the other is 12.75mm. Which one is for the front and which one is for the rear? |
Originally Posted by 201Motorsports
(Post 359351)
(Post 359822)
(Post 359884)
i didn't see the open end short lugs listed on your site, i need them in black.
thank you i just ordered a set, now to find some wheels.
(Post 359937)
(Post 359938)
I could set you up with wheels if you'd like too... let me know what you're looking for and I can get you some pricing!
17" alloy wheels ≈+20 offset 4x114mm non white or chrome |
(Post 360041)
where's my criteria let me know if you have anything that meets it.
Hey Phil, Just took a peek at Ichiba's site, they do have the 50 mm studs with a 14mm & 12.75 knurl. Could you order me 10 of each? Sorry bout not sending my payment yet, didnt have time to deposit $ into my account over the weekend. But for sure, I'll send you the $ for the studs and lug nuts. Oh and I wanted the short open ended Muteki's in black.
Could you also check on pricing for the following rims: Sport Max 006 18x9.5J (their site says they have a 3.5" lip) Sport Max 009 18x9.5J (also 3.5" lip) MB Battle 17x9.5J (+15 offset) Thanks in advance! |
