'For Sale' Suspension / Brakes / Wheels / Tires Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
Power Slot Rotors with free Shipping and 5% off
Old Jun 15, 2004 | 09:48 PM
prostreetonline's Avatar
Heat is the primary cause of ineffective brakes due to fade. There is actually a “boundary layer” of gases that builds up between the pad and rotor surface which inhibits performance. Here’s where Power Slot rotors make a big difference. The exclusive Vac-U-Slots machined into the rotor “wipes” brake pads clean, evacuates gases, and sheds heat. A combination of a “high performance pad” and Power Slot rotors will provide superior reliable braking for virtually all automotive and truck applications, with an upgrade to larger diameter rotors and bigger calipers typically only needed for the most severe competition applications.
Power Slot rotors are manufactured to the highest tolerances keeping SAFETY and quality our number one priority. Slotting, unlike drilling, doesn’t compromise the structural integrity of the rotor. When you drill a rotor you weaken it and cause stress points that can lead to cracking and ultimately failure. Also, drilled rotors lose considerable surface area compared to slotted rotors which means less active braking area for pad to rotor contact.
Power Slot rotors are made using the highest quality Original Equipment replacement blanks. Competitors will sacrifice quality by using inexpensive off-shore castings. Typically these are made of inferior porous material and often have less cooling fins than their OE counterpart. These fins also serve to reinforce the rotor and guard against warpage. Power Slot rotors always meet and/or exceed all OE specifications. It’s also important to know that the exclusive Vac-U-Slot is tapered to enhance evacuation of heat and gases. All machining is done in house to Power Performance Group’s application specific tolerances to ensure optimum quality control.
The final touch is a military-spec cadmium plating that gives Power Slot rotors their bright silver finish and protects the rotor from the elements. This eliminates rusty rotor syndrome and enhances the look of custom wheels.
Click here to order and for full application list:
http://www.prostreetonline.com...otors
Use coupon code PSO5D for 5% off!
peterock29
Apr 19, 2011 09:14 PM
vikter138
Apr 13, 2009 06:05 PM
thearkitekt
Jan 16, 2006 03:53 PM
prostreetonline
May 19, 2004 09:25 PM
jdmsoarer
Apr 7, 2004 02:44 PM
