Cold Air in the rain
Old 04-02-2004, 03:56 AM
cfin3's Avatar
i was wonderin what someones experience with a cold air intake in the rain was. ive heard that it can suck up water into your engine and cause alootta damage. im about to order one but i wanna kno if anyone can help me out
cfin3 is offline
Old 04-02-2004, 11:42 AM
If you have a full on cold air intake, if you hit a puddle and suck up a lot of water say bye bye to your engine. Happened to my friends car...
-HyJynX- is offline
Old 04-22-2004, 03:20 PM
SilviaS14KA24DE's Avatar
not nececssarily. YOu just have to buy an air bypass valve from AEM. THey have different sized for different tubing. You can add it on even if you have lets say, an injen.
The bypass valve allows the engine to intake air through it if the cold air filter is submerged in water. Since the filter may be submereged, the valve kinda actly like a snorkel. Since there will be a presusre change, it will reroute air through the valve. like a short ram air intake
just think. you have a straw, and your drinking soda. now, put a hole that is considerably above the water (soda) line. you won't be able to suck all the drink in full stregnth.
you may think, "well, won't this happen also to the CAI with a bypass valve?" the answer is NO it will not happen. THe bypass valve has "holes" all around you can say. meaning it's sucking in more air through the valve.
the end. lol
SilviaS14KA24DE is offline
Old 04-22-2004, 03:21 PM
and is engineered to do it's job
Old 04-22-2004, 04:48 PM
^^^It all matters on the size of water you suck up, Bypass valves wont work if you hit a big puddle and suck a good amount of water...bye to your engine. Its possible becuase the same thing happened to my friend(same one that I was talking about earlier)
-HyJynX- is offline
Old 04-22-2004, 09:08 PM
ah ic...well then if he's so worried about the cai, then just get a SR lol (short ram, not sr20 )
Old 04-22-2004, 11:59 PM
^^Yea I wouldnt get a full on CAI...I dont trust the bypass valve
-HyJynX- is offline
Old 04-23-2004, 06:18 PM
ooo you're in pasadena. nice
Old 04-23-2004, 07:08 PM
You live around here?
-HyJynX- is offline
Old 04-28-2004, 01:02 PM
That's why the 2-piece CAI's are a little more "pussle friendly" since when it rains you can always convert to "short ram" action
l2aine is offline
Old 04-28-2004, 06:01 PM
^^true.
-HyJynX- is offline
Old 04-29-2004, 12:39 AM
I just realized I typed "pussle" instead of puddle... but since none of us can read anyway, I guess it slid by
l2aine is offline
Old 04-29-2004, 12:49 AM
No it didnt, I noticed it but didnt say anything since I still understood your sentence
-HyJynX- is offline
Old 05-21-2004, 10:05 AM
dvasallo's Avatar
Two Piece CAI
SO What about the tubing going around the motor...I heard that it gets really hot and the tubing actually makes the air hotter...but on the other hand I guess the CAI is forcing more air into your motor...but I dunno if a CAI is good because of the metal tubing that goes around the motor right? So what's the point of getting one?
OH yea who makes good two pieces?
dvasallo is offline
Old 05-21-2004, 11:38 AM
Re: Two Piece CAI
True, the engine's heat will affect the temperature of air flowing through the cold-air tubing, buthere's a simple way to explain why a CAI is better than a short ram - a short ram has the air filter positioned closer to the engine, and when it takes in air, it takes in UNDER-HOOD air, which is hot. A CAI has the filter positioned farther away from the engine, and when it takes in air, it gets a majority of that air from the OUTSIDE of the car (relatively speaking). Both are affected by the engine temp, but the CAI starts with cooler air in the first place, somewhat countering the engine's heat to the CAI pipes.
Also, not all cars have their CAI pipes going around the engine like the 240sx. My old 200SX SE-R had a CAI that wouldn't wrap around the engine like the 240SX configuration. This in turn gave me more power potential than a short ram, which held the air filter approx. 12 inches from the exhaust header.
Finally, check the dyno numbers with CAI testing. They all show the same thing - increased horsepower compared to a short ram.
Oh - and I think Injen has a 2-piece, but don't quote me on that
l2aine is offline
Quick Reply: Cold Air in the rain
