Dual electric fan install for s12/13/14
Old Aug 7, 2005 | 10:45 AM
BigVinnie's Avatar
Whats up guys I came across this s12 page with a very interesting way on how to install the nissan stanza dual radiotor electric fans....
This mod works and is highly recomemnded for the KA, SR, CA, defenitely for RB, and VG engines in the s12/13/14 in order to promote more wheel HP and to keep the engine tempratures lower.
This will also increase engine bay space and make your engine bay look much cleaner......... Technically making it easier to work within the engine bay.
Here is the link what do you guys think......
http://www.v6-s12.com/Projects.htm
You guys dont have to go through half the trouble the one guy did runnin the circuit to the ignition switch, the 240s already come with a secondary electric fan circuit, so it will cut your install time in half......
It would be nice to install the light so that you you know when engine temps are at there peak, that way you can readjust the thermal circuit to kick in at lower temps, if needed.......
Simply install the secondary electric fan circuit to fan 1, and the thermal static switch to fan 2. This will simplify the wiring circuit, this will also allow fan 2 to stay active until the coolant temps have reached a moderate temprature. I would adjust fan 2 to stay active at 120degress Farenheit and higher, that means set the thermal static switch to stay active even when the car is off until it has reached it's desired temprature, kinda like the setup on how Honda sets up there thermal switches on there dual electric fan units.....
This is the next mod that I will aquire after I get the 5zigens from Fast1One, I will leave detailed pics, unless someone beats me to the punch....
Lets make this a sticky fellaz, very usefull mod.........
Old Aug 7, 2005 | 12:16 PM
Slidin240's Avatar
NICE thanx Vinnie. Which yr Stanza's are these fans in? Thanx
Are you doing this to urs? or have it done already?
EDIT: i posted before i read the whole write-up, it says the fans came out of the 91 Stanza. Im going to the junkyard this sunday, imma grab me these fans.
Old Aug 7, 2005 | 12:27 PM
BigVinnie's Avatar
I believe it came in the 91-93 nissan stanza's with the KA24de.
I have not done this mod myself "yet", but I reviewed the FSM, I am pretty thorough with my info.......
I will be doing this mod in about 2 months, looking to drop all the degredation I can from the belt driven in order to get more power from my N/A.......
jramosthe1st!
Jan 23, 2009 10:12 PM
dkdeleon
Apr 1, 2007 01:39 PM
4984 5fsdskfvjdsntr4
Oct 23, 2003 04:10 PM
Doba's240
Oct 20, 2003 09:22 PM
Driftin180SX
Feb 25, 2003 01:51 PM
